Alaska_Stuart
Feb 02, 2017Tutor
RN214 Reports volume capacity at 5% after defrag
I have two RN214, one as a server and the other as a backup. The server is set up as RAID 6, the backup as X-RAID 5. Neither are approaching 10% used. However, both drives consistently report warning...
idf63
Mar 08, 2017Aspirant
I got the message 'Less than 30% of volume media's capacity is free' at 6.28pm 07/03/2017. At 6.37pm on 07/03/2017 I got the message 'Less than 5% of volume media's capacity is free'. I also got 3 AV warnings all relating to Adobe Acrobat folders (backups of installation discs). The alledged viruses are Win.Trojan.Ramnit-5466 (adobe_eula.dll) and Win.Trojan.Magania-11738 (adobe_eula.dll and acro_pro_disc.EXE). Are these real? I have deleted them as instructed but I'm still worried about the volume size. Accoring to the ReadyNAS admin page I have 2.1TB free out of 2.65TB
Mar 08, 2017Guru - Experienced User
It sounds like you are running 6.6.1. There are some issues with the new AV service.
Although Netgear has pushed some (silient) patches, I recommend either disabling AV or installing the current 6.7.0 beta firmware.
The beta firmware can be found here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-7-0-T180-Beta-3/m-p/1229713#U1229713
Read the release notes over before you install.
