Seaglaze
Nov 21, 2018Aspirant
RN3138 Red health LED, No boot menu
After a power interruption our RN3138 is now not booting - after a few seconds the Health LED comes on solid red
If the network is connected that LED is blinking but the admin page is not accessibl...
Nov 21, 2018Guru - Experienced User
What status is RAIDar giving you? Try it both with disks and without disks. https://kb.netgear.com/20684/ReadyNAS-Downloads
Seaglaze
Hi Stephen
It doesn't show up on RAIDar with disks or without
- StephenBNov 21, 2018Guru - Experienced User
Seaglaze wrote:It doesn't show up on RAIDar with disks or without
Unfortunately that suggests that something in the chassis failed. I suggest checking the warranty status (5 years if you are the original purchaser), and trying paid support (my.netgear.com).
BTW, the procedure for the boot menu is on pages 39-40 here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf
It sounds like you are using the correct procedure.
