Seaglaze
Nov 21, 2018Aspirant
RN3138 Red health LED, No boot menu
After a power interruption our RN3138 is now not booting - after a few seconds the Health LED comes on solid red
If the network is connected that LED is blinking but the admin page is not accessibl...
Seaglaze
Hi Stephen
It doesn't show up on RAIDar with disks or without
Nov 21, 2018Guru - Experienced User
Seaglaze wrote:It doesn't show up on RAIDar with disks or without
Unfortunately that suggests that something in the chassis failed. I suggest checking the warranty status (5 years if you are the original purchaser), and trying paid support (my.netgear.com).
BTW, the procedure for the boot menu is on pages 39-40 here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS6_Rackmount_HWM_EN.pdf
It sounds like you are using the correct procedure.
