JohnWill
Apr 24, 2022Tutor
RN314 - Stuck on boot following firmware update
Following a pop up prompt from the web interface of my RN314 I updated the firmware. It downloaded and prompted a reboot. I clicked to reboot but after sometime it hasn't come back online - not vis...
JohnWill
Apr 25, 2022Tutor
Thanks Sandshark . The available space on the volume is low - below 20%. At some point soon I'll replace one or two of the four drives with larger ones.
With regard to those actions is there a preferred order - balance then scrub or scrub then balance? Or does it not matter?
Apr 26, 2022Guru - Experienced User
Personally I'd make sure I had an up to date backup before doing either. But to answer your question, generally there is no preferred order - but in your specific case I'd do the scrub first.
Either way, download the log zip file and look for disk-related or btrfs related errors first.
