kenalker
Feb 11, 2015Aspirant
RN314 and the Recycle Bin
I can not figure out how to enable the Recycle Bin feature on my new RN314. I was using it on the NV+.
- StephenBGuru - Experienced UserMAC text files are compatible with linux, so textedit should work. I think the normal "compress" will create a compatible zip (I'm not a mac user, so I am not sure exactly how to do this, or if there is a simpler way. Perhaps try dragging the updated file into the zip, and see if it takes.
Its always a good idea to have a backup, but particularly important to update them if you are messing about with the configuration or disks. - PWS442GuideThanks Oh Great One! are the lines I want to put into that file, and its location, correct? Will it make any difference in the share display?
- mdgm-ntgrNETGEAR Employee RetiredUsing a config backup restore to do this would have the same support impact as using SSH.
