Waterboy99
Mar 17, 2017Aspirant
RN314 Backups Fail When I Change USB Drives
I'm using v6.6.1. AV is off. I am backing up to external USB drives, which I change every 2 days. When I initially set it up, the back up ran fine the first time. When I change to another drive, ...
- Mar 27, 2017
Hi Waterboy99,
I think what he wanted was to try and re-configure the back-up job to point out the USB location rather than a share.
jak0lantash
Mar 17, 2017Mentor
Is your backup job configured to use a USB port as destination or a USB drive share?
What's the filesystem on the drives?
Do you cleanly unmount it before disconnecting it?
Did that ever work?
Do you read the drives somewhere else between two backups?
Did that ever work?
