Waterboy99
Mar 17, 2017Aspirant
RN314 Backups Fail When I Change USB Drives
I'm using v6.6.1. AV is off. I am backing up to external USB drives, which I change every 2 days. When I initially set it up, the back up ran fine the first time. When I change to another drive, ...
- Mar 27, 2017
Hi Waterboy99,
I think what he wanted was to try and re-configure the back-up job to point out the USB location rather than a share.
jak0lantash
Mar 27, 2017Mentor
Backup to usb port instead of usb share, press and hold backup button to unmount front usb port (iirc), use a dummy backup job to unmount the USB port and add it at the end the backup button job list, there are several things to try and plenty of threads talking about it.
