gpaolo
Nov 25, 2017Luminary
RN314 CPU Temperature
Hi all, I have the feeling that my RN314 has some problem with the CPU heatsink. Temperature is constanly over 65 degrees, with the fan quite noisy. As soon as it does something, the temperature goe...
Marc_V
Nov 28, 2017NETGEAR Employee Retired
hi gpaolo
If your NAS is under five years, I would recommend contacting NETGEAR Support to request for RMA. Otherwise, I would suggest to patiently wait for any recommendations from our community members especially those who have tried opening the RN314. As with NETGEAR, it does not support that procedure and voids the hardware warranty.
Regads
- gpaoloNov 28, 2017Luminary
Hi Marc,
thank you for your reply. The NAS is less than 5 years old, but it is a beta unit, I don't know if it is covered by the warranty. Me, and other users, noticed these high temperatures during the beta program, but I have never seen a clear statement saying "it's ok, don't worry" or "it should be lower, maybe something is wrong with the heatsink". Of course at that time there were not many users to compare the results...
Before opening it, maybe some other user with the same unit could check what is the temperature status in their units? It might be a design choice, after all.
Gian Paolo
- Marc_VNov 28, 2017NETGEAR Employee Retired
Hi gpaolo
If it's a BETA unit hardware warranty might not be included, was it provided by NETGEAR? I think it wouldn't hurt if you try.
Under the manual, acceptable environment temperature is at 0-40C, the NAS CPU should at least be running around 38-50C and fans will adjust accordingly to maintain adequate temperature. If your CPU is running at room temperature of 21C and fans running at full speed, it should at least lower the CPU temp to 60C which I think is acceptable and would be fine.
I hope other RN314 owners can share their unit temperature status.
Regards
