reno1
Apr 24, 2015Aspirant
RN314 drive spin down not working (6.2.3)
Hi, I've just got a brand new RN314 and updated to v6.2.3 (stock was v6.1.6) and cannot seem to get the disk spin down function working. I did some tests to see if the disks spin down, and despi...
reno1
Apr 25, 2015Aspirant
Just to be sure it's not config related, I reset the RN314 to factory settings and it then proceeded to reconfigure the disks to XRAID (RAID 1) as per default. I then let the data resync to complete (takes several hours). I also had nothing else changed from the default factory settings apart from time zone, hostname and enabling the disk spin down feature.
EDIT: Should have also mentioned that I tested with both network connected and disconnected (just to make sure nothing else is trying to access disks).
Unfortunately I'm still seeing the same symptoms and the disks are not spinning down.
I have sent in the logs for the above test as per your request mdgm.
Thanks
Thanks
