cleveland_rocks
Jul 03, 2020Aspirant
RN314 won't power up
This morning (3 July 2020), my Netgear RN314 did not power up as usual. It is a 4 disk system running OS 6 with the latest firmware. I tried changing the outlet for the external power supply brick, and the system started for 2 seconds and shut off again. After looking on the forums, this is probably a bad brick or power regulation subsystem. The discussion here seems to explain the problem.
I've ordered a new power supply from eBay, so I hope that works. If the problem is the internal subsystem, I would not attempt a repair (I don't think parts are available anyway.) Used 314s on eBay not worth the price! Replacing it with a newer 4 bay NAS from Netgear also does not seem to be an option as the RN424 was discontinued in December 2019. Other options are over $1,000 and I would rather build my own server at that point.
Would it be possible to take the existing healthly 4 x 4TB drives in RAID 10 configuration to a new Linux server of my own build? How could this be done without data loss? I have a full backup of the RAID on another external drive from 5 days ago, but I would still like to migrate as easy as possible.
It's actually a separate RAID with a separate set of partitions, but I think that's what you meant. fdisk -l will show you all the partitions. If you have more than one drive size or have ever upgraded from smaller drives without an OS re-install, the main BTRFS volume will span more than one RAID "layer".
- SandsharkSensei
The ReadyNAS RAID is created by standard Linux MDADM and the volumes are standard BTRFS. So, they can be mounted on a standard Linux system that includes those packages. The 4GB OS partition, however, is not enough for a typical Linux installation, so you'll have to use something else for that.
- cleveland_rocksAspirant
Thanks for the reply. I'm relieved to hear that there is a pathway for migration of the existing RAID.
Do I understand you correctly that Netgear put a 4GB partition on the RAID to run their OS 6? My intention was to build a server running Xen on its own physical SSD and then have my 4 x 4TB hard disk RAID mounted on that system. I'll have to check whether Xen has the two packages you mentioned.
Thanks again.
Yes, and also a small swap partition. The OS partition is RAID-1 (mirrored on every disk). I've seen a couple of different RAID formats used for the swap.
You can of course do that, since you don't need to mount the OS partition.
