jukkaforss
May 16, 2017Tutor
RN314 FW 6.7.1 root partition full, how to fix ?
Hi, I rebooted my readynas and after boot GUI didn't start, cli is still working fine. I logged in and it seems that root partition is full, but not full. It says 100% full, but there is only 1,...
- May 18, 2017
Skywalker fixed root fs somehow, and not it is working fine.
jak0lantash
May 16, 2017Mentor
To be able to look "under" mountpoints, mount-bind the root volume to /mnt:
mount --bind / /mnt
Then look inside it:
cd /mnt du -d1 -h
It will tell you which is the biggest folder, then cd into it and re-run:
cd <big_folder> du -d1 -h
Repeat the operation until there is no more big folder, only the total is big, which means it's big file(s) in the current directory, then:
ls -lhS
When you're finished cleaning up the big files, unmount the temporary bind:
cd umount /mnt
jukkaforss
May 17, 2017Tutor
jak0lantash wrote:To be able to look "under" mountpoints, mount-bind the root volume to /mnt:
mount --bind / /mntThen look inside it:
cd /mnt du -d1 -hIt will tell you which is the biggest folder, then cd into it and re-run:
cd <big_folder> du -d1 -hRepeat the operation until there is no more big folder, only the total is big, which means it's big file(s) in the current directory, then:
ls -lhSWhen you're finished cleaning up the big files, unmount the temporary bind:
cd umount /mnt
It is not possible to remove files, rm command always gives error.
root@readynas:/mnt/var/cache/apt/archives# rm libgsm1_1.0.13-4_amd64.deb rm: cannot remove 'libgsm1_1.0.13-4_amd64.deb': No space left on device root@readynas:/mnt/var/cache/apt/archives#
- jukkaforssMay 17, 2017Tutor
Is there a way to to factory reset with out disks, so that data volume is saved ?
I need to get this system up and running as soon as possible !!
- jukkaforssMay 18, 2017Tutor
