WarCon
Oct 20, 2017Tutor
RN314 OS 6.8.1 - Win10 Pro 64-bit Fall Creator 1709 - Can't access Shares
Hi A few days ago I have created a new instance of Win 10, and this has just upgraded to Win10 1709 Fall Creator. Before upgrading to 1709 the instance was connected to the shares, and the shares w...
kohdee
Nov 08, 2017Administrator
You can get Windows to force credentials either via Mapped Network Drive or using Windows Credential Manager
- evan2Dec 12, 2017NETGEAR Expert
the root cause is Win10 1709 doesn't allow access SAMBA using guest accout,
it try to access NAS using windows login account and password,
if you add a same account on NAS, you may access NAS, and you will find it login using the windows login account,
6.9.2 T build has fixed the issue.
if not all shares disable guest access, set "map to guest = bad user" in smb config,
if all shares disale guest access, set "map to guest = never" in smb config.
Note: if set "map to guest = never", Windows will pop-up login page to let user input user name and password,
Win10 1709 want to access NAS via Samba,
all shares need to disable guest access on NAS.
- StephenBDec 13, 2017Guru - Experienced User
Using credentials on all the windows systems works too, and would allow SMB guest access for other devices (older media players for instance).
- SkywalkerDec 13, 2017NETGEAR Expert
There are a couple other ways to get this working on <= 6.9.1 without touching Windows group policies.
1) Create a user account on the NAS that matches the name of the user that you're logged in to Windows as. So, if your Windows account name is stephenb, create a NAS user account named stephenb.
2) Change the SMB3 Transport Encryption option to Required. (However, this will have a major performance impact on RN31x and lower desktop models)
