jjcf89_2
Jan 04, 2019Tutor
RN314 smb issues, kernel hang
Running OS6.9.4 hotfix
This morning samba file shares where behaving strangely. Some machines could access some files and not others. Some couldn't open at all.
dmesg showed there was s...
- Jan 15, 2019
Upgraded to OS 6.9.5 stable. So far NAS has been running for 6 days and no crash.
Jan 04, 2019Guru - Experienced User
You could try installing 6.9.5-RC1, and see if that helps.
Or downgrade to 6.9.3, which solved it for me.
- jjcf89_2Jan 04, 2019Tutor
How do I find the release notes for 6.9.5?
- StephenBJan 04, 2019Guru - Experienced User
https://community.netgear.com/t5/ReadyNAS-Beta/ReadyNASOS-6-9-5-RC1/m-p/1656915#M10309
Thanks. Are there any known issues with the 6.9.5 beta?
