martin9911
Nov 13, 2013Aspirant
RN314 will not Backup to HFS+
Hi! I´m trying to setup my RN314 to backup a "share" to an external USB-drive. The drive has HFS+, which is supported according to technical specifications on RN300 series. When trying to backup I ge...
martin9911
Nov 18, 2013Aspirant
Did an OS reinstall and got the USB-ports back. Created a backup job and all seemed to go well backing up data. After a couple of hours backing up I changed "tab" from backup to System in the web GUI. ReadyNAS crashed and now I cant access anything. Looking at the unit all seems ok but the display will not "light-up" but i can see what it shows if i use a flashlight on it. It displays ReadyNAS IP-Address. Just as it should. Also the backup button blinks. No activity on the USB-drive used for the backup job.
I had a Netgear Stora 4 years ago but sold it because it was so unstable. Thought Netgear should have learned a thing or two in four years but it does not seem that way... Why implement functions that has so low reliability. Sucks!
