mrg_arg
Jun 01, 2017Aspirant
RN316 - problems after 6.7.4 - not booting
I upgraded to 6.7.4 a few days ago, and shut the system down a couple days after that. When I tried to reboot, I got "mount_block_root +1f1" error. I found discussion about fixing that with USB re...
MacRob
Jun 02, 2017Aspirant
I have the exact same issue, but I havent gotten it to the diagnostic mode.
Still trying different flash drives, and trying rufus.
I can get it to "booting from external usb" but t seems to hang there, or some drives it will go back to booting then fails.
mdgm-ntgr
Jun 02, 2017NETGEAR Employee Retired
MacRob, please replace the initrd.gz and kernel on the USB key with these:
https://www.readynas.com/contributed/mdgm/r6usbboot/latest/initrd.gz
https://www.readynas.com/contributed/mdgm/r6usbboot/latest/kernel
and try again.
- MacRobJun 03, 2017Aspirant
Thanks, but still no luck. I tried manually copying the files to the flash drives after usbrecovery (format+install) is done. Then used rufus to format, usbrecovery to install, then manually copy.
Then I put files in x86 folder and let usbrecovery install after formatting with each option.
Then I deleted all of these files, redownloaded and tried all again (thought maybe something was corrupt)
They all still hang at "booting from external usb".
- mdgm-ntgrJun 03, 2017NETGEAR Employee Retired
Can you confirm you're using a USB key with the MBR partitioning scheme and a single partition on it?
Do you have another ReadyNAS or just this one?
