Platypus69
Apr 18, 2017Luminary
RN316 | Won't start up | 6.7.0 Problems I assume
Hi all, So what do I do now? My RN316 does not come up after a reboot. Have been running 6.7 for a while, but I suspect this was the "first reboot". Upon powering up it gets to around 28%...
- May 01, 2017
Thanks.
Am wondering why that was checked...
Anyway, it's gone.
Was able to upgrade to 6.7.1.
Trick was to refresh home page which them said that 6.7.1 was loaded and would be installed on next reboot.
Or perhaps the trick was that I stopped the scrub first.
In any case 6.7.1 is running, and the boot is substantially quicker than before!
Thanks all.
mdgm-ntgr
Apr 18, 2017NETGEAR Employee Retired
My guess would be you're running into an issue that's addressed by ReadyNASOS 6.7.1-T244 (Beta 1)
So you could try updating to that and if it still won't boot do an OS Re-install.
Platypus69
Apr 19, 2017Luminary
So I can do that from "Read-Only" mode?
Can I wait for 6.7.1?
Is there an ETA for it? 1 week? 1 month?
- mdgm-ntgrApr 19, 2017NETGEAR Employee Retired
In volume read-only mode the data volume is read-only, not the root volume.
If you can't access the GUI you could go to https://ip.address.of.nas/fwbroker
Yes, you can wait for the production release if you want.
We hope it will be ready soon but as for an ETA providing one can lead to disappointment if it the ETA is not met.
- Platypus69Apr 20, 2017Luminary
I've worked in IT for over 30 years, so I used to disappointment :catlol:
Ummm... otherwise, can I delete the snapshots whilst in read-only mode.
In my case I have 12TB of data and 21GB of snapshots which I do not really need.
Is there something I should be configuring in read-only mode reagrding the quotas?
TIA
- mdgm-ntgrApr 20, 2017NETGEAR Employee Retired
You could try an OS Re-install on 6.7 as that will disable quotas on the volume. However if you change share settings that will re-enable quotas on the volume (there's a fix for this in 6.7.1).
