Platypus69
Apr 18, 2017Luminary
RN316 | Won't start up | 6.7.0 Problems I assume
Hi all, So what do I do now? My RN316 does not come up after a reboot. Have been running 6.7 for a while, but I suspect this was the "first reboot". Upon powering up it gets to around 28%...
- May 01, 2017
Thanks.
Am wondering why that was checked...
Anyway, it's gone.
Was able to upgrade to 6.7.1.
Trick was to refresh home page which them said that 6.7.1 was loaded and would be installed on next reboot.
Or perhaps the trick was that I stopped the scrub first.
In any case 6.7.1 is running, and the boot is substantially quicker than before!
Thanks all.
jak0lantash
Apr 30, 2017Mentor
It's officially released already.
https://kb.netgear.com/000038557/ReadyNAS-OS-6-Software-Version-6-7-1
mdgm-ntgr
May 01, 2017NETGEAR Employee Retired
I would suggest you update to 6.7.1 as the next step.
- Platypus69May 01, 2017Luminary
Thanks!
So I've downloaded and unzipped: ReadyNASOS-6.7.1-x86_64.zip
Then I went to System > Settings and clicked on the Install Firmware button and attempted to upload the ReadyNASOS-6.7.1-x86_64.img file.
Nothing happened in web portal.
Nothing happening on OLED screen.
I then noticed that the RN316 is scrubbing data. It's a 15.01% and slowly ticking over. In a couple of minutes it has progressed to 15.08%. Of course it's configured to scrub on the 1st day of the month, of course... :smileylol:
Would that block the upgrade?
Remember I am in Read-Only Data Volume mode, or whatever it is called.
Is there anything else I should do? Or is it simply a matter of trying again to Install firmware and upload IMG file and seeing how you go?
TIA
