Platypus69
Apr 18, 2017Luminary
RN316 | Won't start up | 6.7.0 Problems I assume
Hi all, So what do I do now? My RN316 does not come up after a reboot. Have been running 6.7 for a while, but I suspect this was the "first reboot". Upon powering up it gets to around 28%...
- May 01, 2017
Thanks.
Am wondering why that was checked...
Anyway, it's gone.
Was able to upgrade to 6.7.1.
Trick was to refresh home page which them said that 6.7.1 was loaded and would be installed on next reboot.
Or perhaps the trick was that I stopped the scrub first.
In any case 6.7.1 is running, and the boot is substantially quicker than before!
Thanks all.
bedlam1
May 01, 2017Prodigy
Using the Admin page got to System....go to Volumes....Click the Gearwheel....check or uncheck Quotas
Platypus69
May 01, 2017Luminary
Thanks.
Anyway, it's gone.
Thanks all.
