Kardano
Apr 18, 2019Luminary
RN316 how to contact Netgear support???
Hello,
after update FW from 6.9.5 to 6.10 my RN316 wont boot and stop at samba service. I saw it once on another unit. If i do OS reinstall teaming will be destroyed an unit boot again normally...
Kardano
Some other info.
RN316 stops at 86 percent of booting with nmb.service. raidar see unit as: System is starting up.
I have SSH access to the unit. can anyone help me with my unit in this state so i can do some backup?
Kardano
I resolved booting with OS reinstall SSH command from Chirpa, so my data are accessible now.
I need to contact Netgear and do something with my unit's touchpad. (RMA perhaps) but with NO case number and no phone for EU.... Can anyone from Netgear help me please?
Thank you.
- Retired_MemberApr 18, 2019
Hi Kardano, there are some phone numbers to contact Netgear in Germany behind this link. Fortunately, I did not have to try this so far.
https://www.netgear.de/home/contact-us/
For other European countries you might want to try modifying the link accordingly.
Godd luck and kind regards
- KardanoApr 25, 2019Luminary
NO HELP OR CONTACT from anyone from Netgear....but i get this e-mail:
Hello ${recipient.login},
A reply to a topic you are following has been accepted as a solution!
Topic: ${thread.topicMessage.subject} Author: ${thread.topicMessage.author.login} (${thread.topicMessage.author.ranking.name}) Date: 2019-04-18 09:44 AM Some other info.
To manage your notifications, click here.
If this link doesn't work:
- Log on to NETGEAR Communities.
- Click My Profile.
- Click the Subscriptions & Notifications tab.
- Change your settings and click Save Changes.
Thanks for being a NETGEAR Communities member.
- StephenBApr 25, 2019Guru - Experienced User
Have you tried calling them? Another option is to directly request an RMA from my.netgear.com ("replace my defective product" on https://www.netgear.com/mynetgear/portal/myOnlineTicket.aspx)
You can also try sending an email to [email protected].
Also, have you checked the warranty status on your RN316? Might be good to confirm that it is still covered before you reach out again to support.
Hello,
i tried request RMA from my.netgear.com ("replace my defective product") and i get respose with NO case number (as is shown on 1st entry of this conversation). Netgear messed up my unit registration so now my.netgear.com (and repairing registrations is not done after nearly a year from reporting to them) telling me that i have NO HW warranty (I bought RN316 2017/12) Funny.
Problem on my RN316 is thar front touch panel is freezing sometimes. Stay lit and not accepting any touch. Seems like no big problem, but in this case i need to go to Boot menu. I get into the boot menu...and panel is lit and unresponsive. I tried more than 10 time. no help. i waited about an hour in bootmenu, no help. So with unresponsive touch panel i am unable ti use boot menu. Not a good options.
i try to write to the Netgear e-mail. I was hoping that someone from netgear may to chweck if there is some case no for me or not.
- JohnCM_SApr 25, 2019NETGEAR Employee Retired
Let me check if I can help you with this.
You can PM me the serial number of the NAS and also the email address that you are using for your MyNETGEAR account.
