Desmoquattro83
Apr 18, 2016Aspirant
RN31600 and RAID1 with 5 disks
Hello all. I just bought a RN31600 and need to use it with 5 disks in RAID1 mode. However, as long as i put more than 2 disks in, the option only allows to create raid5 or raid6 with my 5 drives. I...
- Retired_MemberApr 18, 2016
Creating a RAID1 on 5 HDDs is possible from SSH though.
Don't know if I should advise that, it depends on your experience in Linux systems.
I tried it on my unit and it worked:
## Switch to Flex-RAID from GUI ## Destroy the current volume from GUI (obviously, this wipes all data there is on it) # mdadm --create --verbose /dev/md127 --level=mirror --raid-devices=5 /dev/sd[a-e]3 [...] # cat /proc/mdstat Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md127 : active raid1 sde3[4] sdd3[3] sdc3[2] sdb3[1] sda3[0] 483536832 blocks super 1.2 [5/5] [UUUUU] [>....................] resync = 1.4% (6895616/483536832) finish=114.8min speed=69136K/sec # mkfs.btrfs -L `hostid`:data /dev/md127 [...] # mount /dev/md127 /data mount: mount point /data is not a directory # ls -al /data lrwxrwxrwx 1 root root 9 Apr 18 03:50 /data -> /dev/null # rm /data # mkdir /data # mount /dev/md127 /data # mount | grep md127 [...] # df -h [...] ## Check that volume is seen from GUI ## Reboot gracefully from GUI to finalize procedure (so ReadyNAS OS mounts everything it needs,
anna_arun
Apr 18, 2016NETGEAR Expert
Raid 1 does not function that way , Raid 1 with 5 Drives is not possible .Raid 1 or Raid 1+0 (Raid10) needs multiples of 2 Drives . Each HDD has a Mirror copy .
Best you can do is Raid 10 with 4 Drives and use one drive as hot spare or use 6 Drives on Raid10
Retired_Member
Apr 18, 2016RAID1 with 1 HDD and 4 mirrors is a perfectly valid RAID. It's just not possible on ReadyNAS...
RAID1 and RAID10 are two different things.
