Desmoquattro83
Apr 18, 2016Aspirant
RN31600 and RAID1 with 5 disks
Hello all. I just bought a RN31600 and need to use it with 5 disks in RAID1 mode. However, as long as i put more than 2 disks in, the option only allows to create raid5 or raid6 with my 5 drives. I...
- Retired_MemberApr 18, 2016
Creating a RAID1 on 5 HDDs is possible from SSH though.
Don't know if I should advise that, it depends on your experience in Linux systems.
I tried it on my unit and it worked:
## Switch to Flex-RAID from GUI ## Destroy the current volume from GUI (obviously, this wipes all data there is on it) # mdadm --create --verbose /dev/md127 --level=mirror --raid-devices=5 /dev/sd[a-e]3 [...] # cat /proc/mdstat Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md127 : active raid1 sde3[4] sdd3[3] sdc3[2] sdb3[1] sda3[0] 483536832 blocks super 1.2 [5/5] [UUUUU] [>....................] resync = 1.4% (6895616/483536832) finish=114.8min speed=69136K/sec # mkfs.btrfs -L `hostid`:data /dev/md127 [...] # mount /dev/md127 /data mount: mount point /data is not a directory # ls -al /data lrwxrwxrwx 1 root root 9 Apr 18 03:50 /data -> /dev/null # rm /data # mkdir /data # mount /dev/md127 /data # mount | grep md127 [...] # df -h [...] ## Check that volume is seen from GUI ## Reboot gracefully from GUI to finalize procedure (so ReadyNAS OS mounts everything it needs,
Desmoquattro83
** edited due to my error, forgot to reboot the nas **
everything works as planned. I assume hotplug and autorebuild are still enabled after doing this ?
Cheers again !
mdgm-ntgr
Apr 18, 2016NETGEAR Employee Retired
Sure, but if you run into issues support can't be expected to help with a volume that couldn't be created using any of our UI options.
Your latest post indicates just why what you've done is something that support would deny help for.
You may need to enter an entry for the data volume to /etc/fstab doing e.g.
echo 'LABEL='`hostid`':data /data btrfs defaults 0 0' >> /etc/fstab
You may then need to do e.g.
# systemctl restart readynasd
and hope that the necessary entries in the database are created.
- Desmoquattro83Apr 18, 2016Aspirant
Thanks but actually everything regarding creating shares works perfectly from the GUI now i've rebooted the unit.
