dannieboiz
Jul 14, 2016Tutor
RN4200 no longer accessible
Problem seems to appear since I updated to the current firmware. For the past week, Frontview has been failing to load everyday, files are accessible. I would reboot the unit and the system woul...
Jul 14, 2016Guru - Experienced User
Did you have ssh enabled?
- dannieboizJul 14, 2016Tutor
Stephen, yes, SSH is enable..
While I was waiting, I decided to pull the plug on it and plug it back in. I was able to gain access to frontview again. Before doing anything else, I downloaded 6.5.1 and upgraded it manually.
I remember when I got the message for 6.5.1 and accepted it and let it update automatically but I was still on 6.5.0. Something probably went south with the update. I'm gonna see how 6.5.1 do for the next few days.
