gn00347026
Nov 14, 2017Guide
RN422 - OUT_OF_MEMORY+2F9
Network Topology NAS (NFS) --1G Switch -- ESXI 6.x I've one rn422 which is running on fw 6.9.0, the main purpose is only for testing purpose and it is stand-by for data backup in-case the prim...
- Nov 16, 2017
after downgrade to 6.8.1 , problem resolved~
Nov 14, 2017Guru - Experienced User
Is Antivirus enabled? How about file search?
- gn00347026Nov 14, 2017Guide
Hi stephe
no snapshot, no anti-virus, no file search, just nfs enabled
BR
- StephenBNov 14, 2017Guru - Experienced User
Something is likely wrong. Have you looked at disk health? How full is the volume?
Though it looks like there are enabled services that you can turn off. ReadyDLNA shows up in the log, and can certainly be turned off.
One option is to turn off all non-essential services and then attempt to balance and defrag. Anoter is to do a factory reset and start over.
HI Stephen
thank for your reply.
it just purchased, both HDD are health, all "0" on smart_history.log,
Around 10% Free.
I will downgrade back to 6.8.1 and factory default to the RN412 and try again.
I will turn off the unused services
wanna to see the logs?
