Numb3r6
Nov 03, 2021Apprentice
RN422 front panel issues, again
Options for models seem limited so to be clear, my NAS is ReadyNAS 422 2 bay with 2x3TB drives Firmware is up to date with 6.10.5 hotfix 1 Firstly I'll cross reference 2 other issues I've had wit...
Nov 07, 2021Guru - Experienced User
Deeperdown wrote:
re-flashing the OS - how did you do this? I am currently have the very same problems
You aren't re-flashing, you are installing new firmware (which ends up on both the NAS flash memory and the disks). Note the NAS boots from the disks.
Download the firmware for your NAS (either arm or x86), and unzip it. Then go to system->settings->update and use the install firmware control there. It will update your firmware (and tell you when you need to reboot the NAS).
Deeperdown
Nov 07, 2021Tutor
thanks. how do i know if it is arm or x86?
