bmaro's avatar
bmaro
Guide
May 27, 2018
RN422 Hard Drive Issue
RN422 Ready Nas with Firmware 6.9.3.  This is a new machine that came diskless.  I purchase two-WD Red 6TB NAS Hard Disk Drive - 5400 RPM Class SATA 6 Gb/s 64MB Cache 3.5 Inch.  They are on the compatibility list.  They were bought brand new
The RN422 can only see one of the disks.  Slot 1 was showing one disk and Slot 2 was showing empty.  I shutdown the unit and switched the disks so that the disk that was showing in slot 1 was now in slot 2 and the disk that was in slot 2 not showing was in slot 1.  After doing that, the disk in slot 2 was showing and the disk in slot 1 was not showing.  This would lead me to believe there is an issue with the disk but is there any other tests I can run before returning the disk?  Thanks.
  • bmaro wrote:
    I hear a weird noise coming from the disk like a spinning noise and a sort of beeping noise.
    The beeping noise means the disk failed out-of-the-box (note the disk has no speaker, so this chirp is being generated by the moving parts within the disk).
    Exchange it with the seller, as RMAing it with Western Digital will get you a recertified replacement with a much shorter warranty.
  • I also tried reseating the drive by remove it from the drive tray reinserting it then inserting it back into the nas.  when i do that the light comes on after about 15 seconds but before the light comes on I hear a weird noise coming from the disk like a spinning noise and a sort of beeping noise.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      Can you send in your logs (see the Sending Logs link in my sig)?
      You could try hooking the disk up to your PC and testing it using WD Data LifeGuard Diagnostics.
    • StephenB's avatar
      • bmaro's avatar
        bmaro
        Guide
        thanks new drive finally came in and that was it, all is good.
ProSupport for Business
