bmaro
May 27, 2018Guide
RN422 Hard Drive Issue
RN422 Ready Nas with Firmware 6.9.3. This is a new machine that came diskless. I purchase two-WD Red 6TB NAS Hard Disk Drive - 5400 RPM Class SATA 6 Gb/s 64MB Cache 3.5 Inch. They are on the compa...
- May 28, 2018
bmaro wrote:
I hear a weird noise coming from the disk like a spinning noise and a sort of beeping noise.
The beeping noise means the disk failed out-of-the-box (note the disk has no speaker, so this chirp is being generated by the moving parts within the disk).
Exchange it with the seller, as RMAing it with Western Digital will get you a recertified replacement with a much shorter warranty.
bmaro
May 27, 2018Guide
I also tried reseating the drive by remove it from the drive tray reinserting it then inserting it back into the nas. when i do that the light comes on after about 15 seconds but before the light comes on I hear a weird noise coming from the disk like a spinning noise and a sort of beeping noise.
May 28, 2018Guru - Experienced User
- bmaroJun 27, 2018Guide
thanks new drive finally came in and that was it, all is good.
