Numb3r6
Nov 03, 2021Apprentice
RN422 front panel issues, again
Options for models seem limited so to be clear, my NAS is ReadyNAS 422 2 bay with 2x3TB drives Firmware is up to date with 6.10.5 hotfix 1 Firstly I'll cross reference 2 other issues I've had wit...
Nov 07, 2021Guru - Experienced User
Deeperdown wrote:
thanks. how do i know if it is arm or x86?
The KB article has a list of the applicable ReadyNAS after each of the two download links.
Deeperdown
Nov 07, 2021Tutor
Thanks for your help. Basically I guess if I leave it for the time being until the new firmware is pushed out it will be picked up by the automatic update of the NAS and resolve the issues?
- StephenBNov 07, 2021Guru - Experienced User
Deeperdown wrote:
Basically I guess if I leave it for the time being until the new firmware is pushed out it will be picked up by the automatic update of the NAS and resolve the issues?Yes - it might take a week or so (depending on Netgear).
The manual install process is easy - if you are confused about the Arm/x86 aspect, you can just tell us what ReadyNAS you have. If it's a desktop, then any model number over 300 is x86, the models below 300 are Arm. FWIW, if you make a mistake on this, the system will refuse to install it.
