Numb3r6
Apr 30, 2021Apprentice
RN422 weird message on front panel
ReadyNAS RN422 2 bay and weird front panel message Unit is just over 2 years old and so far I've been happy with performance and reliability. This morning, following usual scheduled start via Power...
Apr 30, 2021Guru - Experienced User
I have noticed a bizarre message on the front panel as follows:
(null)+ffffea0001d29000
Can anyone cast any light on this?
The NAS crashed. There could be more information in the full log zip that might give more details on what was running when the crash occured.
Does the system come up normally when you reboot it?
- Numb3r6Apr 30, 2021Apprentice
Thanks for the quick reply, much appreciated.
If the NAS had crashed, it seems odd that I could still access the shares from my devices...or is that to be expected?
In terms of startup, yes, all seemed normal and had it not been for the front panel message I would have been none the wiser with no clues in logs and shares seemingly working normally.
I've just had another look at logs from last night into this morning and see nothing unusual, as follows:
Last night's auto shutdownApr 30, 2021 12:00:09 AM System: The system is shutting down.
This morning's auto startupApr 30, 2021 08:01:29 AM System: ReadyNASOS background service started.
Apr 30, 2021 08:01:31 AM Snapshot: Snapshot prune worker successfully deleted snapshot 2021_04_02__00_00_00 from share or LUN Applications.
(ditto for another x5 shares)Apr 30, 2021 08:18:21 AM System: Antivirus scanner definition file was updated to 59.26155.
Then my manual shutdown and reboot...Apr 30, 2021 11:18:23 AM System: The system is rebooting.
Apr 30, 2021 11:21:56 AM System: ReadyNASOS background service started.
I've dumped the logs via ZIP as suggested, but really don't know where to start as there are so many files. If you could possibly suggest where to start looking or if sharing here might be of value, I'd be grateful!- StephenBApr 30, 2021Guru - Experienced User
I've dumped the logs via ZIP as suggested, but really don't know where to start as there are so many files. If you could possibly suggest where to start looking or if sharing here might be of value, I'd be grateful!It sounds like a process on the NAS crashed, but it was still partially up.
Start in kernel.log and search for the error string (ffffea0 is likely enough).
- Numb3r6May 01, 2021Apprentice
Thanks for that suggestion. As it happens I'd already considered kernel.log as a good starting point but when I first looked into it realised I didn't know what I was looking for really, so that string search made sense. I did try that but got no hits at all. If there are other files from the log dump I should home in on I'd appreciate any pointers, given there are an awful lot of them!
I did also come across this thread, which discusses very similar issues (string is not exactly the same) and seems to be related to some IPv6 glitch
https://community.netgear.com/t5/New-ReadyNAS-Users-General/RN314-Front-Panel-Null-ffffffff880fa4cf/td-p/2041281
That said I've checked my router IP tables (the NAS is set to use a constant DHCP address) and it says "This device either does not support or is not configured for IPv6 addressing"
System has started normally today BTW
