ricardorios33
Feb 18, 2016Follower
RN4220X with ArcServe 16.5
Hi
I have a server with ArcServe 16.5 working on my network. This server has a 450 GB SAS disk capacity. 70 PCs are connected on LAN and do the backup with Arc Serve, then pull information fr...
Feb 19, 2016Guru - Experienced User
I don't know about ArcServe, but there are two basic approaches you can take.
One is to use iSCSI, which the NAS sees as opaque block-based storage.
The second is to use the NAS btrfs file system, which would require that you mount NAS shares on the server (either with SMB or NFS).
I don't know which is better for ArcServe (or if it has direct support for NAS).
