berillio's avatar
berillio
RN424 , 4x 8TB WD Red Plus failing after 120 days? Part 2
This is the continuation of
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN424-4x-8TB-WD-Red-Plus-failing-after-120-days/m-p/2122231#M193062
I just posted the reply below - it appeared as accepted and then, as I clicked "reply" again, to add all the findings of teh last two hours,  it flashed a "denied" to me, so I don't really understand what's happening
I am having problems posting my replies. I posted  the one below 3hours ago, and it never seemed to appear, but I only noticed 1h ago. Lets try again. -
Apologies, I thought I posted the message (within the “==”)  last week, but I must have prepared the reply but NOT pressed the “Post” button.
Then, of course, I was checking the mails for eventual replies which never came. Sorry !
The disk is SO dead that the WD utilities could not even see it (neither Lifeguard Diagnostic DLGDIAG 1.37 nor the “Dashboard”).
Seagate Seatools for Windows saw it, tested it and failed it
--------------- SeaTools for Windows v1.4.0.7 ---------------
Short DST - Started 30/07/2021 21:04:19
Short DST - Pass 30/07/2021 21:06:06
Identify - Started 30/07/2021 21:21:31
Model: EFAX-68KNBN0
Serial: 152D20337A0C
Firmware: Unknown
Model Number: WDC WD80EFAX-68KNBN0
Serial Number: VGJL3SDG
Firmware Revision: 81.00A81
Drive Capacity: 8.00 TB / 7.28 TiB
Max LBA: 15628053167
Cache Size: 256 MB
Power-On Hours: 2930
Drive Temperature (C/F): 46 / 115
WWN: 5000CCA0BEE46BC8
Sector size (Logical/Physical/Allignment): 512 / 4096 / 0
Rotation rate: 5400 RPM
Form factor: 3.5 inch
Specification Supported: ACS-2
Encryption Support: Not Supported
Security Mode: Supported
SMART: Enabled
Host Protected Area features: Enabled
Advanced Power Management: Enabled
Download Microcode: Segmented, Deferred
Short Generic - Started 30/07/2021 21:24:55
Short Generic - FAIL 30/07/2021 21:26:46
Victoria also saw it, as fail it immediately too.
On the 424 I run the extended disk test as adviced. The test completed on Saturday afternoon. I received an email stating that it had been completed, no mention of any Warning or Errors, I presumed it was ok, but I just downloaded the logs, and in volume.log, the last line reads:
“data        disk test  2021-07-30 20:54:30  2021-07-31 13:49:00  pass”.
The other advice was:
“The bay in the NAS might also have failed - if you have a spare disk, you might try doing a factory install (with only the spare disk inserted, in bay 1).  Then power down and move the disk to bay 2.  Power up, and make sure it works. If you try this test, label the disks by slot as you remove them.”
Do you mean a factory default as in
https://kb.netgear.com/23114/How-do-I-reset-the-firmware-on-my-ReadyNAS-OS-6-storage-system-to-factory-defaults
or  via Option 2 in the boot menu (P97 on the HM manual) – (I presume it is the same operation)
I guess that it would format the ”spare disk” (I don’t have a free one, but I suppose I can re-clone one 50Gb hd with a spare W7 copy I have)
Update – I eventually managed to find a free-ish SATA disk on some PC, backed it up, and low-level formatted it. I am just about  putting in the RN424 in Slot 1. I imagine it should do a factory default automatically; after that I will switch it off and try the other slots.
1 Reply
  • StephenB's avatar
    FYI, this was in the spam filter, that was why it didn't show up immediately.
ProSupport for Business
