berillio
Jul 30, 2021Aspirant
RN424 , 4x 8TB WD Red Plus failing after 120 days?
This problem is with a RN424 with 4x 8TB WD80EFAX, all identical HDs purchased at the same time as the 424. The system has 6.10.4 Hotfix1 and has been up for 120 days, I had not even transferred all ...
berillio
Oct 11, 2021Aspirant
Hi all, sorry for the delays
Tue 5 Oct at 21:55
Disk Model:WDC WD80EFBX-68AZZN0 Serial:VRGRW69K was added to Channel 2 of the head unit.
Tue 5 Oct at 21:55
Resyncing started for Volume data.
Wed 6 Oct at 15:30
Volume data is resynced.
Wed 6 Oct at 15:30
Volume data health changed from Degraded to Redundant.
Pfeww Hurray
Thank you to all for the support
Added note – WD has not replaced the failed disk yet.
When I will receive it (if I do), I could get another NAS, maybe a 2 bay one, and I could twin it with another 8TB on RAID 1, purely for backup duties.
Unfortunately NETGEAR seems to have disappared from the UK market, for reason I cannot really fathom.
One simple question – in the event of a NAS failure – can a RAID1 disk be read by any LINUX machine or would I need recovery software (which is kind of pricey)?
Oct 11, 2021Guru - Experienced User
Yes. You would need to install mdadm and btrfs on the linux system. But no paid software packges are needed.
- berillioOct 15, 2021Aspirant
@@Stephen B wrote:
Yes. You would need to install mdadm and btrfs……….
Thank you :-)
Updates
Wednesday 13 October 2021 ~ 15:30
UPS parcel, WD80EFAX S.N. VGGW8JKK ; 256 MB cache 5400 rpm (? I thought it was 7200rpm..?)
Disk goes on test with DLGDIAG, Quick test Passed, starting Extended test (on my USB system ~60-70 h)
Thursday 14 October 2021 14:02 – Too Many Bad Sectors (after 22h10m, 44h49m remaining)
Mailed WD with the screencap of DLGDIAG
Did somebody put a Jinx on me ???
- StephenBOct 15, 2021Guru - Experienced User
It is 7200 rpm. https://www.pcmag.com/news/western-digital-confuses-everyone-with-5400-rpm-class-hard-drives
Note after this came out, WD put 7200 rpm on their datasheet (with a footnote talking about the performance class). Not sure if they updated the firmware to report the actual speed.
Ouch. That possibility is why I also test mine before putting them in my NAS.
