tijgert
Sep 03, 2014Guide
RN516 CPU upgrade
Ever looking to improve on performance I'm looking for a way to upgrade the CPU on my RN516. The CPU obviously must support ECC memory and have a (FC)LGA1155 socket with a max TDP of 55W. LGA1155 wi...
Sep 03, 2014Guru - Experienced User
Netgear warranties are not transferable. If the original owner registered the product, then tijgert will not be able to re-register.
xeltros wrote: IF you can claim the warranty through him then you are good indeed. I'm not sure Netgear will actually check if this is a second hand device while opening a case, and even if they do, it could have been offered to you or bought by someone else for an enterprise, not sure how they could check that. So if you have the original purchase proof
Of course if the original owner chose not to register it, then tijgert would be able to do so, esp. if he has the original sale information.
