tijgert
Sep 03, 2014Guide
RN516 CPU upgrade
Ever looking to improve on performance I'm looking for a way to upgrade the CPU on my RN516.
The CPU obviously must support ECC memory and have a (FC)LGA1155 socket with a max TDP of 55W.
LGA1155 will work just the same, I read in several places.
The question now is, to anyone that knows or can find out, is there any bios support for other CPU's?
- xeltrosApprenticeI used the VM today to check some things on volume creation/deletion (by the way, it works in virtualbox, but ESX shows only one disk, even though x-raid resyncs perfectly, but it is hard to play with volumes with a single selectable disk). I didn't have any problem after updating it via GUI.
This would mean that :
- There is a mechanism to remove the CPU code (I suppose flash is reproduced somehow too)
- or the hypervisor did a good job emulating a supported CPU
- or the CPU code is in the bios
- or there is no CPU restriction
- or that VM uses specific repository - mdgm-ntgrNETGEAR Employee RetiredWell what I should have said is the hard coding in the firmware may restrict the range of CPUs that will work well to a smaller selection than those supported by the BIOS.
There are flags so the VM knows it is not running on real hardware.- BaJohnVirtuoso
Apologies about going back to Warranty issue.
Just for my clarity .....
I live in the UK, so if I die and my RN516 has outstanding warranty, the warranty dies with me!
Is that correct?
A simple Yes or No from a person whom is 100% certain about it will do.
Thanks.
- IcyKTutor
Never ask a lawyer for a simple yes or no without providing all the details of the case ;)
From what I read on these forums, I am 95% sure the answer from Netgear perspective will be 'yes'.
Being a laywer in The Netherlands myself, I am 100% sure the answer from EU consumer perspective will be 'no'.
But from EU consumer perspective, the end-user has to deal with the retailer in warranty cases, not with the manufacturer. So your children will have to deal with the shop you bought the NAS from, and the shop will have to fix the problem (either by doing it themselves, or by requesting / ordering the manufacturer to fix it).
I don't know the answer in a business envoronment. I do know EU consumer law usually does not apply in dealings between professionals.
Also, I guess nobody will go to court over a couple of dollars / pounds / euro's, so the question is higly theoretical imho.
If you have enough money to go to court, you'll also have enough money to buy a new NAS and save yourself the troubles of a trial.
If you don't have 500 euro's for a new NAS, you probably also don't have the 5000+ euro's to go to court...
(This will be my only response in this matter.)
