jah313
Sep 18, 2023Tutor
RN516 Drive expansion not syncing the drive
Hi All, I have an RN516 (FW 6.10.8) with six 2TB drives and am running out of space. I have 6 new 8TB disks that are from the approved list. I swapped out disk 6 with one of the new drives and al...
jah313
Sep 18, 2023Tutor
Thank you so much for the info.
One problem, all of my computers are MACs đ
I do have an enclosure I could test it with but I am not sure what software to use on the mac to check the drives. Do you have any advice?
Also, if it checks out, can I format just that drive on the NAS by highlighting and clicking format on the right of the screen?
Sep 18, 2023Guru - Experienced User
Unfortunately none of my computers are Macs.
An alternative is to use ssh to get into the NAS, and then run the long smart test using smartctl. Have you ever used ssh?
You could try that, yes.
