jpass022's avatar
jpass022
Luminary
Jul 27, 2016
RN516 Vertical Expansion for volumes over 16 TB
Does the no autoexpand with volumes above 16TB limitation still exist? Is there any explanation to why this limitation exists?
  • Backed up NAS and did the factory reset, which fixed the expansion problem as it should have. I checked the available apps page while the Nas was resyncing and it was populated, but this morning, the available apps page is empty. I manaully loaded PLEX and it installed properly and the icon is present on installed apps page. The available apps page is still empty?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    That limitation has never affected our OS6 x86_64 products such as the RN516.
    It was a limitation of EXT4 which we used for the data volume on legacy systems.
    There were also some limitations on OS6 ARM (even though we use BTRFS for the data volume) on firmware prior to 6.4.0 due to our ARM products being 32-bit.
    • jpass022's avatar
      jpass022
      Luminary
      mdgm,
      Thanks for the info. Do you have any suggestions to fix my non-expansion after reboot problem then? I know I could spend a few days transferring all the Shares off the NAS and do a factory reset, but I'd rather not if there is an alternative I can try...
      • StephenB's avatar
        What exactly did you try to do (e.g., what was your starting disk configuration, and what did you change)???
ProSupport for Business
