jpass022
Jul 27, 2016Luminary
RN516 Vertical Expansion for volumes over 16 TB
Does the no autoexpand with volumes above 16TB limitation still exist? Is there any explanation to why this limitation exists?
- Aug 01, 2016
Backed up NAS and did the factory reset, which fixed the expansion problem as it should have. I checked the available apps page while the Nas was resyncing and it was populated, but this morning, the available apps page is empty. I manaully loaded PLEX and it installed properly and the icon is present on installed apps page. The available apps page is still empty?
mdgm-ntgr
Jul 31, 2016NETGEAR Employee Retired
An OS Re-install wouldn't fix this, but once you have your backup I wouldn't see any harm in trying that.
jpass022
Aug 01, 2016Luminary
- jpass022Aug 01, 2016Luminary
UPDATE : problem solved with PLEX Apps...
- Sep 06, 2016Retired_Member
