jpass022
Jul 27, 2016Luminary
RN516 Vertical Expansion for volumes over 16 TB
Does the no autoexpand with volumes above 16TB limitation still exist? Is there any explanation to why this limitation exists?
- Aug 01, 2016
Backed up NAS and did the factory reset, which fixed the expansion problem as it should have. I checked the available apps page while the Nas was resyncing and it was populated, but this morning, the available apps page is empty. I manaully loaded PLEX and it installed properly and the icon is present on installed apps page. The available apps page is still empty?
mdgm-ntgr
Jul 27, 2016NETGEAR Employee Retired
That limitation has never affected our OS6 x86_64 products such as the RN516.
It was a limitation of EXT4 which we used for the data volume on legacy systems.
There were also some limitations on OS6 ARM (even though we use BTRFS for the data volume) on firmware prior to 6.4.0 due to our ARM products being 32-bit.
jpass022
Jul 28, 2016Luminary
mdgm,
Thanks for the info. Do you have any suggestions to fix my non-expansion after reboot problem then? I know I could spend a few days transferring all the Shares off the NAS and do a factory reset, but I'd rather not if there is an alternative I can try...
- Sep 06, 2016Retired_Member
