nickjames
Sep 06, 2017Luminary
RN516 End of life and failure scenario
Hello, I'm buying a used RN516 from a client of mine, that I've managed throughout the years and I had a few questions- 1.) When does the RN516 go end of life? 2.) In the event that unit had...
Sep 06, 2017Guru - Experienced User
The hardware warranty is not transferable, so the end-of-life doesn't really apply to you. As far as manufacturing goes, the RN516 has already been replaced with the RN526x.
Note that Netgear won't provide software support for used ReadyNAS either - with the exception of data recovery services.
- nickjamesSep 06, 2017Luminary
I was not really concerned with the hardware warranty as the device was originally registered to me and is under warranty until 2018 so there's not much time left anyways.
I was more trying to find out how much longer the operating system will be upgraded and if new features will be implemented.
Also, generally speaking, if the device were to fail, how does one move the array to another device that is not a ReadyNAS? Is this easily done?
Thanks, StephenB
Nick
- StephenBSep 06, 2017Guru - Experienced User
No signs of deprecating OS-6, and they are continuing to introduce new OS-6 platforms. So you are safe on that for the forseeable future.
It is straightforward if you have an x86 linux system that has btrfs installed.
