Govnah
Apr 27, 2013Aspirant
RN516 Memory Upgrade
Curious if anyone knows if it is possible to upgrade the memory on the RN516? From what I can gather, the RN516 is using one slot (2 available) with a single innoDisk 4GB 1600 W/ECC DIMM, model # M3C...
tijgert
Sep 03, 2014Guide
Ok, so 8GB total would be more than sufficient. I that case I'll gladly add another 4GB so as to use Dual channel and thereby doubling the memory bandwidth already.
Would the 516 be very critical about not 100% similar sticks of ram? I mean, it'd be ECC and 1600MHz and 1.35v and such, just not the same brand.
