Govnah
Apr 27, 2013Aspirant
RN516 Memory Upgrade
Curious if anyone knows if it is possible to upgrade the memory on the RN516? From what I can gather, the RN516 is using one slot (2 available) with a single innoDisk 4GB 1600 W/ECC DIMM, model # M3C...
mdgm-ntgr
Sep 03, 2014NETGEAR Employee Retired
The x86_64 firmware is a separate image to the ARM firmware so the x86_64 firmware can be optimised to run best with 2GB+ of RAM.
Having said that you can run it with less RAM.
