Govnah
Apr 27, 2013Aspirant
RN516 Memory Upgrade
Curious if anyone knows if it is possible to upgrade the memory on the RN516? From what I can gather, the RN516 is using one slot (2 available) with a single innoDisk 4GB 1600 W/ECC DIMM, model # M3C...
mdgm-ntgr
Sep 23, 2014NETGEAR Employee Retired
If you download the logs zip file, one of the logs for the memory shows this. You can see how much is being used for caching and how much swap is used. If you are using a lot for caching but not swap then a memory upgrade likely won't make a significant difference. However if you are using your swap a lot then a memory upgrade may make some difference.
We don't support memory upgrades, but you can do them on our models which use Intel CPUs e.g. the Ultra 6. If you do do one on be sure to run at least a few passes of the memory test boot menu option.
