Govnah
Apr 27, 2013Aspirant
RN516 Memory Upgrade
Curious if anyone knows if it is possible to upgrade the memory on the RN516? From what I can gather, the RN516 is using one slot (2 available) with a single innoDisk 4GB 1600 W/ECC DIMM, model # M3C...
RezzZ
Sep 24, 2014Tutor
Thanks all!
I'll check the logs tomorrow after my backup jobs are all finished... backing up to USB sucks. takes me 2,5/3 days to copy 6TB.
I assume I can just run the memory test from putty and watch from there too right? Don't need to hook up a screen for that?
