Govnah
Apr 27, 2013Aspirant
RN516 Memory Upgrade
Curious if anyone knows if it is possible to upgrade the memory on the RN516? From what I can gather, the RN516 is using one slot (2 available) with a single innoDisk 4GB 1600 W/ECC DIMM, model # M3C...
RezzZ
Sep 24, 2014Tutor
tijgert wrote: Dude.. I had to copy 24TB times 2... I've been busy setting it all up for over a month now...
How does putty work then?
if you have EnableRootSSH_1.0-x86 installed on your readynas you can login with putty via ssh. You can then execute any command as if you are in the terminal window on any other linux machine.
