adinx
May 24, 2017Aspirant
RN516 "mount_block_root + 1f1" after os 6.7.3 update
Hi there, I tried updating from 6.7.2 to 6.7.3 today and it has killed my Readynas. Now I have the error mount_block_root +1f1 whenever it boots. I have tried to do the usb recovery but i...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
If you can't do USB Boot Recovery despite trying multiple different USB keys and following the directions you'll need to contact support.
adinx
May 25, 2017Aspirant
I tried everything possible but couldn't get it to work. Got really frustrated. Did an RMA and they are sending the replacement.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
Well McRob1 got it to work: https://community.netgear.com/t5/Using-your-ReadyNAS/Firmware-Update-from-6-7-1-to-6-7-3-Has-Failed/m-p/1290420#M130602
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
