michaeldowns
Feb 17, 2021Tutor
RN526X Hardware Cache on Motherboard.
Hi All, I have 2 RN526Xs and while upgrading RAM to 32GB on each, I have noticed that the bottom of the mobo has an open slot. I have a couple of questions: 1) is it a M.2 slot or mSATA? 2) is su...
Feb 18, 2021Guru - Experienced User
michaeldowns wrote:
2) is such a cache memory upgrade supported in the OS v6.10.4?
No, and just opening the chassis could have voided your warranty.
Information here says it is mSATA: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Add-SSD-drive-s-to-RN528X/m-p/1805740#M38176
michaeldowns
Feb 18, 2021Tutor
Thanks StephenB,
Performance improvement is worth the risk of warranty. The memeory expansion from 4GB to 32GB has been excellent.
So, from what you mention, adding a mSata to the open slot will not affect NAS apps (Plex, etc.) performance; correct?
Just to be clear.
Thanks again,
mdd
