Deal
Oct 09, 2019Tutor
RN626X - order for adding disks when 2 of the 6 disks are larger than the other 4
I don't know if X-RAID on OS6 has a limitation in how disks of different capacities are added to a volume. So I have a basic question about adding disks to the RN626X on OS6. I will have a total ...
- Oct 09, 2019
Install the smallest disks (2x10TB disks) first.
If you install the 2x12TB disks first you won't be able to add the 10 TB drives later.
Oct 09, 2019Guru - Experienced User
Deal
Oct 09, 2019Tutor
This confirms what I thought would happen. I had hoped that they'd removed that limitation in OS6. Thanks!
- SandsharkOct 10, 2019Sensei - Experienced User
The way they vertically expand the volume, this limitation will never go away. It's not much of a limitation when you consider that the ability do do expansion with different sized drives at all is a feature many systems lack.
If you install the 10TB first, it will create a RAID1 of 10TB. When you add the 12TB, it will expand the 10TB "layer" to RAID5 with 10TB from each of the 12's and add a 2TB RAID1 layer on top with the remainder. If you start with 12TB's, it cannot expand that first layer because the new drives are too small.
It is possible to get around this manually via SSH, but creating a system that will do so automatically and still allow for future expansion is not easy without building in some limitations.
