emielwe
Sep 24, 2017Aspirant
RND-4A, error: no disk detected
ReadyNAS RNDP4420, RND-4A. 1 disk inserted 320Gb,formatted with Windows PC, running W7 PC and NAS connected via switch to internet The RND-4A was not used for years and all original disks are gone...
Sep 26, 2017Guru - Experienced User
emielwe wrote:
If I use the "Frontview" even without disks inserted should I get the status of the NAS?
You can't, since the system boots from the disks.
Are you seeing anything on the LCD screen? Did you try doing a factory install from the front panel? ( http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf )
Normally you want to insert blank (unformatted) disks, so it might be worth deleting the existing partitions with windows disk manager.
emielwe
Oct 04, 2017Aspirant
Hello,
As requested I booted in "Factory install" from the boot menu
Got after som time the error message: No disks detected
I used one 320Gb disk, first time formatted in ext4 the the same disk NTFS formatted
Still the same error mess.
- StephenBOct 04, 2017Guru - Experienced User
What disks are you using?
- SandsharkOct 04, 2017Sensei
The NAS must format it's own drives, so don't waste any more time trying that. It also will format them in OS4.2.x without warning, so don't use a drive that has anything on it you care about. You appear to have a hardware problem -- either the drive or the NAS. Did you try the other slots or another drive?
