albertnas
Mar 08, 2014Aspirant
RND v1 backup with frontview not working
I have a ReadyNAS Duo v1 running RAIDiator 4.1.12. I want to simply backup my NAS. I hoped to program the frontview RAIDiator 4.1.12 but ran into problems. When I go to add a new backup job, I do t...
vandermerwe
Mar 08, 2014Master
If you go to Frontview click on backup then backup jobs the job you created should be there. If it is not you did not save it.
Did you click on Apply after you setup the job?
The backup button will (by default) backup the backup share to the USB drive attached next to the button. You can however program this button to perform any of the backup tasks you have setup. The backup button settings are also under backup in Frontview.
With regards this particular backup job, how did you initiate it if you deactivated the schedule and cannot see the job in the listing. Those would be the only ways that the job could start unless you had programmed the job into the backup button list.
How is your USB disk formatted?
I think if the job isn't there you should program it again, make sure you click apply at the bottom. When you see the job in the list, start it and see what happens. If it does not work, post all the settings of the job and any error messages you receive.
