albertnas's avatar
albertnas
RND v1 backup with frontview not working
I have a ReadyNAS Duo v1 running RAIDiator 4.1.12.
I want to simply backup my NAS.
I hoped to program the frontview RAIDiator 4.1.12 but ran into problems.
When I go to add a new backup job, I do the following:
1. For the source I find my share listed and select it. Since it is listed, I assume that I do not need to enter a path. I cannot use the test connection button.
2. For the destination, I select the Share USB_HDD_1 since I have an external USB drive plugged into the front face. Again I cannot use the test connection button.
3. I deselect the backup schedule.
4. I Schedule full back up first time and send errors only to email. No other boxes checked below.
I get the following error: "Error in evaluating table display tb TypeError:Unable to get property 'firstChild' of undefined or null reference"
The next message says the job was saved but I cannot see it to edit it or use it.
I was reading an online manual which said the default function of the backup button was to backup the entire nas to the usb drive on the front face. when I push it something happens but i'm not sure what. No new data is copied onto the usb drive. the log shows that a backup was started and finished in less than one minute.
Can you help? I am not a tech whiz so please try to keep your comments simple for my primitive mind.
Thanks for any support you can offer.
Albert
  • StephenB's avatar
    albertnas wrote:
    ...A sample line from the log is "`./temp/pics for jan 14 2013/DSC00769.JPG' -> `/USB_HDD_1/temp/pics for jan 14 2013/DSC00769.JPG'"
    albertnas wrote:
    Still trying to find out how I can use/retrieve the files directly from the backup on my HDD.
    The file "DSC00769.JPG'"should be in "\temp\pics for jan 14 2013\" At least that is what is supposed to happen.
    What size/model is the USB drive?
  • It's a WD My Passport Ultra 2.0TB with USB 3.0 compatible with USB 2.0
ProSupport for Business
