morph1
Sep 21, 2013Aspirant
RND2000-200 ReadyNAS Duo V2
Hi all , just purchased this external device, I have several problems , one is I am unable to power off the device with the power button, I held it for 10 sec nothing, I pushed it twice fast nothing,...
vandermerwe
Sep 21, 2013Master
With the duo v2 you need to push the power button twice to power down.
I would suggest not pushing it too quickly.
Holding the power button down doesn't work.
If you need to force a shutdown you need to unplug the power.
